Hello
I recently had enough problems with ECDC 5, that I decided to use Nero to burn my VCD's.
But...
I seem to have noticed that thye VCD's burned with Nero do not look as good as the ones burned with ECDC 5....
The VCD's I've burned with Nero looked more "blocky"...(I'm not sure if I'm using the right expression here)
Is this possible...?
Has anyone else noticed this..?
Can I do something about this problem...?
Thank you for your help
I presume you are talking about encoding and burning, not just burning. If you burn any VCD-compliant mpg with any VCD burning software, this will not make the picture quality suffer. The short advice, if you are using these progs to encode, is don't. Use one of the guides here to encode using TMPG, then burn with Nero.
Good plan!Originally Posted by banjazzerAs Churchill famously predicted when Chamberlain returned from Munich proclaiming peace in his time: "You were given the choice between war and dishonor. You chose dishonor, and you will have war."
Yes I agree with you, I already use TPMG to encode the mpg-1 's and then I burn them using Nero.Originally Posted by banjazzer
But as I said before, I still seem to notice that the VCD's I make with Nero look more "blocky" than the ones I made with ECDC 5.
Is there a setting in Nero I should be looking at to fix this problem..?
I am using the authoring with Nero 5.5+ instructions provided by this site.
Quality loss in all programs except for VLC
By Dozza in forum Software PlayingReplies: 3Last Post: 21st Jun 2011, 11:33 -
mkvmerge - no quality loss?
By gustav32 in forum DVD RippingReplies: 1Last Post: 20th May 2009, 15:56 -
Encoder with no quality loss
By JamesDV in forum MacReplies: 25Last Post: 8th Apr 2009, 12:01 -
DVD to AVI - without quality loss?
By maxamillion in forum DVD RippingReplies: 7Last Post: 16th Dec 2008, 17:25 -
video quality loss
By majax79 in forum Video ConversionReplies: 2Last Post: 24th May 2008, 02:03
