  1. I just recently downloaded a movie.
    Right now, I just extracted the movie (well parts of it)
    Actually, the movie is in sections.
    It's a CD1 & a CD2.
    I extracted it and now the movie is a BIN file
    What do i do next??
  2. You mention a "CUE file" in the subject. If you have CUE files, you can use Nero to burn those, even though you have to select "All Files" to see them (just select "Burn Image" from the File menu).
    If you have just plain old BIN files, I don't think you can do anything with them. You'll need a corresponding ISO or CUE file to use them... but I could be wrong. I'm only familiar with Easy CD Creator and Nero.
  3. what does this mean???
    C:\WINDOWS\Desktop\SURFACE\Martin.Lawrence.Live.Ru nteldat.UNCUT.TS-tNB\CD1\tnb-ml-rtd-cd1
  4. Is this a quiz?
    Looks like a path to a folder. Is this popping up as an error?
  5. You can burn bin files with with nero.Don,t use wizard,simply click on file than burnimage and select image that you want to burn.Nero sometimes burns certain bin files wrong,if this is the case fireburner almost always will burn these images right.
  6. You may need to fix the CUE file by editing the path to point to the actual bin file. The easiest way is to simply put the cue and bin files in the same directory and deleting everything from the PATH in the CUE file except for the name of the bin.
    Then, use a program that actually knows what a CUE/BIN image is (e.g., CDRDAO /VCDEasy, CDRWin or the newer versions of Nero).
    Regards.
    Michael Tam
    w: Morsels of Evidence
