Hi all, Im new to all this stuff just 2 questions:
First, here is what it says when I use Smart Ripper :
ASPI-Adaptor available
try to lunlock drive...
no ASPI access to this drive
switch to WinIO
test file access....
goes through a bunch
VTS_01_1.V0B-> WinIO locked
Then a popup comes and says "Some files are still locked ! Try to unlock with a player.
So im not sure what to do because nothing will write??
Also can someone direct me to a guide for converting DVD to SVCD? I looked at Sefy(s) but since I cant get the first part working im not sure if this outputs to SVCD? If it does just tell me thanks
dunk
Sefy's are some of the best.....but sometimes you have to fill in some of the gaps by yourself.....
Anyhow...I always play the dvd on my pc using powerdvd or what have you...then when you get into the movie..hit pause...and open smartripper...I've never had anyfiles locked that way. Once smartripper starts ripping you can close powerdvd or other app. -
First thank you for the lovely comments!
As for your problem, make sure you installed an ASPI Layer for your windows and that it's v4.61 (not v4.7x!) and i'm pretty sure everything will work great!Email me for faster replies!
Best Regards,
Sefy Levy,
Certified Computer Technician.
Smart Rendering and MPEG 2 HD?
By miepel in forum EditingReplies: 16Last Post: 20th Jan 2011, 01:27 -
Get Smart backup
By Shermanbay in forum DVD RippingReplies: 26Last Post: 12th Nov 2008, 00:54 -
GET SMART no copy
By shoesss in forum DVD RippingReplies: 3Last Post: 7th Nov 2008, 10:48 -
Menus not shown in DVD Decrypter or Smart Ripper
By EmpireStrikesBack198 in forum DVD RippingReplies: 2Last Post: 11th Jun 2008, 17:48 -
Smart ripper help
By holland11 in forum Authoring (DVD)Replies: 4Last Post: 13th May 2007, 02:15
