I have problems frameserving to TMPG using VirtualDub, when I open the file in TMPG it looks fine, but when I try to encode it it gives an error message "The error occurred when ACM was initialized." and then usually (but not allways) gives another message "Illegal floating decimal point calculation order." The problem is probably with the sound becuase when I select 'No Audio' in VirtualDub and then frameserving it there's no error and the encoding is excellent. I don't know why this is happening but I can tell you it used to work for me in the past, so please help me.
Results 1 to 1 of 1
Frameserving From VirtualDub to MainConcept
By hech54 in forum Video ConversionReplies: 0Last Post: 8th Mar 2012, 09:24 -
Problems re-using VirtualDub
By djdust in forum Newbie / General discussionsReplies: 17Last Post: 27th Apr 2011, 08:57 -
virtualdub dv type 2 problems
By sander815 in forum Video ConversionReplies: 26Last Post: 21st Nov 2009, 19:58 -
Problems with Virtualdub
By demonwarrior in forum Newbie / General discussionsReplies: 4Last Post: 8th Jun 2007, 09:23 -
A couple of VirtualDub problems.
By Rein Engel in forum Capturing and VCRReplies: 5Last Post: 1st Jun 2007, 03:07
