I have a MPEG2 file and it's about 680MB. After I use the I-Author to generate the .cif file, it's only 670MB. I then use the CDMage to check the .mpg file size and it shows 690MB! Because my CD-bruner is not supported by CDRWIN, so I convert .cif to .bin and burn it with fireburn.
My CDR media is 700MB but seems like the burner doesn't use the whole capacity. The movie is missing around 1 min or more at the end. Does anyone know have the same problem?
Results 1 to 1 of 1
TMPGEnc DVD Author question/
By ingeborgdot in forum Authoring (DVD)Replies: 11Last Post: 22nd Sep 2008, 13:58 -
question on TmpegencDVD author
By perfection in forum Authoring (DVD)Replies: 2Last Post: 3rd Jul 2008, 07:45 -
New TMPGEnc DVD Author Question
By Robert Simandl in forum Authoring (DVD)Replies: 1Last Post: 11th Jun 2008, 07:47 -
TMPGEnc DVD Author 3 Question ...
By ZaYoOoD in forum Authoring (DVD)Replies: 5Last Post: 3rd Dec 2007, 07:17 -
By newtie in forum Authoring (DVD)Replies: 1Last Post: 4th Sep 2007, 09:49
