I'm trying to convert using TMPGEnc from Quicktime files to MPEG 1 for a VCD. The video is coverting fine, but I seem to be turning them into silent movies. Anyone with any ideas on what I could be doing wrong....or should I paste in a piano back track and some caption card shots?
NB I have read the CONVERT guides and I have installed Quicktime and the relevant files for TMPGEnc to recognise QT
Try This;
Select options > environmental settings
right click the quicktime plugin and select higher priority -
Thanks for the suggestion. I've tried it now - it didn't give me any sound, but it did make the picture quality dreadful.
Should I be extracting the audio first with some other software, or should I just be able to specify the same .MOV file for both video and audio sources?
Quicktime/MOV files in TmpGenc
By buddycat in forum Video ConversionReplies: 2Last Post: 20th Mar 2009, 21:54 -
No sound in MOV och MP4 when I use quicktime pro
By Cazz in forum Video ConversionReplies: 2Last Post: 3rd Sep 2008, 15:02 -
Problem converting quicktime .mov files to mpeg-1
By jtk in forum ffmpegX general discussionReplies: 8Last Post: 2nd Sep 2008, 18:42 -
trouble converting Quicktime mov. to avi (on windows XP)
By pifkel in forum Video ConversionReplies: 3Last Post: 31st Dec 2007, 04:19 -
Suggestion for converting hundreds of mov quicktime files
By m021478 in forum Video ConversionReplies: 0Last Post: 15th Aug 2007, 15:16
