i just got a yamakawa dvd player and some vcds play great with little to no blockiness. but then, i put in a vcd, and it was blocked to all hell. was it a bad burn or was it the file?
Probable cause is that the VCD's not looking good has a lower bitrate than VCD standard, and/or uses a lower resolution. Most DVD players handles non standard VCD's.
May be your player only supports full standard discs.
Or your VCD is made of an bad avi file. -
maybe the vcd's were burnt at a high speed. some dvd players have trouble with discs burnt at high speeds.
i burned it at 1x and it didn't work and what do you mean by standard discs? the asian vcds? if so, then no, thats not it cause some of my vcd's work and others wont.
The developer of VCD´s and SVCD ( mpeg1, 2) defined standards for VCDs/SVCDs ( 352 * 288 Pixel for VCD Pal ). Some DVD Players only work stable when the VCD is burned in this standards. The same is valid for SVCD ( 576 * 480 Pixels ).
Try to play it with your Computer VCD- Player.
When its not playable the theres an error in the file. -
http://www.vcdhelp.com/vcd.htm
BTW. (width x height)
VCD: PAL ( 352 x 288 ), NTSC (352 x 240 )
SVCD: PAL ( 480 x 576 ), NTSC ( 480 x 480 )
Regards.Michael Tam
w: Morsels of Evidence
Standalone player will not play DVD
By Chala in forum Newbie / General discussionsReplies: 12Last Post: 16th Sep 2010, 03:09 -
HT - dvd player in the pc or a standalone?
By Haopengyou in forum Media Center PC / MediaCentersReplies: 5Last Post: 6th May 2010, 07:39 -
Xvid AC3 file playback problem on Standalone DVD player
By kamol88 in forum Video ConversionReplies: 2Last Post: 21st Mar 2009, 03:38 -
DVD playing in standalone player but not on PC
By Leo48 in forum Newbie / General discussionsReplies: 2Last Post: 28th Jun 2008, 09:35 -
Problem with playing DVD in standalone player
By tngolfn in forum Newbie / General discussionsReplies: 2Last Post: 14th May 2007, 17:41
