  1. is there a way to rip everything on a dvd like the chapters with the movie, the menu it has and everything. So then movie u burn can come out with everything the original has:interactive menu,chapters, and so forth.
    if so, can dvd decryptor do it?
  2. Yes you can,usining Info Edit but you have to rip the DVD and copy it to 2dvd's its a long process but it works.
  3. As long as the disc you are ripping is Single Layered, you can just use Dvd Decrypter to rip EVERY FILE. After that there should be a VIDEO_TS folder on your harddrive somewhere.
    Go and boot up NERO and select DVD VIDEO. Drop the VIDEO_TS folder into the compilation window to replace the original empty VIDEO_TS folder. Burn away. When you are done you should have an exact duplicate of the movie disc that you are trying to get.
    If it's Dual Layered, you'll hafta rip and re-encode and by then you probably won't have the chapter menu and everything or whatnot.
