Hi people!
I have a problem with capturing video. I'm using the Video-In feature of my Asus V8200 Deluxe (GeForce3, 64MB).
I'm using the latest Display/WDM nVidia Drivers.
When trying to capture video in programs like VirtualDub, freeVCR, I get this error:
"Video device already in use. You cannot use this device when another video application...."
Then a "Video Source" window opens, and I need to select a video source. The only thing I can choose is
"ASUS WDM Video Captrue (universal)". both VirtualDub and freeVCR result the exact same error (same text, same error window), so I can assume that my problem is not an application-specific problem.
An exception to my problem is "Asus Digital VCR", since in that application, I got no error. My guess is that the "Asus Digital VCR" is not using the "ASUS WDM Video Captrue (universal)" driver.
I should mention that no TV-related applications are running in the background... I even tried to capture right after a reboot, and I got the same error...
The problem started when I accidently tried to delete the VirtualDub directory while the program was running (I wanted to replace it with a new version). I got an error saying that some files couldn't be deleted, so I closed the application, deleted the directory, and replaced it with a new version of VirtualDub (1.4.10). Since then, I get the error...
I tried uninstalling and reinstallting the WDM & the Display drivers... It didn't work...
Pleaseee help me
Thank you,
Eyal
Same problem here, but not resolved
http://forum.vcdhelp.com/viewtopic.php?t=106418
HDMI device that can capture (unencrypted) "HD" audio sources?
By jalyst in forum Capturing and VCRReplies: 70Last Post: 28th Mar 2017, 13:45 -
What's the most "Device Compatible" container? is it, .mp4 or .mkv?
By thezanny in forum Video ConversionReplies: 11Last Post: 3rd Jan 2012, 08:07 -
DVD with menus, replacing "bad" video with "good" video
By chipsndukes in forum Authoring (DVD)Replies: 34Last Post: 4th Dec 2008, 17:45 -
Need help...Newbie who's just bought "EasyCap" USB Capture Device
By RICHM0802 in forum Capturing and VCRReplies: 1Last Post: 19th Sep 2008, 01:18 -
Error "no usable writing device installed"
By saramalik in forum DVD & Blu-ray WritersReplies: 5Last Post: 23rd May 2008, 03:42
