i am trying to convert avi to dvdr but run into problems . spruce up does all the work but when i go to burn the video
-ts file it says DVD-VIDEO reallocation failed. can any one help me get passed this to burn to dvd r. i am using nero5.5.8.2
would it not be better to encode the avi with cce or tmpgenc which would give you more control over the size and quality and then import resultin file into your authoring program
you reap what you sew -
He's right...use TMPGenc for the encoding, spruce for the authoring and Nero for the burning...
Reallocation error might be a diskspace problem, since spruce copies teh final result to it's working dir.
Greetz..
Mike. -
well that depends...
If you encode for pal, make a pal dvd project.
if you encode for ntsc, make a ntsc project.
depending on what country you are in.
Framerate converion or wrong framerate may be yoru problem.
How to burn AVI to DVD without converting
By ss4nemis in forum Newbie / General discussionsReplies: 16Last Post: 19th Nov 2012, 20:43 -
Converting AVI to DVD
By PhaedraUK in forum ffmpegX general discussionReplies: 10Last Post: 7th Jan 2008, 08:15 -
Spruce Encoders
By zerohash in forum Authoring (DVD)Replies: 1Last Post: 12th Sep 2007, 05:10 -
Create Root menu for avi's on DVD without converting each avi?
By Ghtpua in forum Authoring (DVD)Replies: 2Last Post: 7th Sep 2007, 23:23 -
Converting AVI to DVD - Only 3Gb
By Mutenroy in forum ffmpegX general discussionReplies: 4Last Post: 2nd Aug 2007, 17:21
