Hi everybody,
I've tried to extract the MPEG out of a BIN files using VCDGear but the result is a bunch of files for a total of 1.4 GB. Some of the files has the same size: maybe are they the video and audio streams? How can I recognize 'em?
Thank you for your support
Riccardo![]()
.dat ? double click one of them, and select Open With > Windows Media Player
Thank you for your help, but maybe the problem is not so simple (for me at least): I already open them: some are video files some others audio files (but I couldn't hear anything), some are empty (lenght was 0:00).
I'm a little confused as you may guess.
Thank you once again
Riccardo -
Ok, you would probably be better off using an ISO buster, then you can see the structure of the disk.
WinISO or ISO buster should be just fine
MPEG Streamclip MPEG-TS to MPEG4/H264 (file size & aspect ratio query)
By Heathy65 in forum Video ConversionReplies: 5Last Post: 4th Apr 2012, 12:31 -
Extracting Video and Audio Question
By rede96 in forum DVD RippingReplies: 2Last Post: 5th Jun 2010, 12:40 -
extracting the bin/cue from .oo1,.002 etc files
By belwas in forum Newbie / General discussionsReplies: 5Last Post: 7th Jan 2010, 01:59 -
question about extracting idx/sub files from DVD
By jimdagys in forum SubtitleReplies: 2Last Post: 24th May 2008, 10:49 -
question about extracting subtitle (srt ) file from IDX/SUB files
By jimdagys in forum SubtitleReplies: 2Last Post: 13th Nov 2007, 14:26
