  1. Guest
    have a problem with a mpg file. MPEGproperties is teling me the mpg file has not valid mpg audio header. How can i fix?
    Jul 2002
    Salem, OR
    I always get this message when checking SVCD mpg files so I just assumed it doesn't like them. The files themselves have always tested ok, so it may be nothing to worry about.
  3. Guest
    i cant play it at all i receive a error msg "no combination of filers could be lfoudn to render the stream"
    then, i used the option mpeg ->mpeg on vcdgear. and the audio header problem has gone.
    then i tried playing the new mpg and it has alot of green lines on the image, cant play at all.
    then i used virtualdub to open the orignal and new one file but i got errors open them "pack synch error on packet stream" and "pack synchronization erro" respectively.
    i also use mpeg corrector but didnt work either.
    anyone can help me?
    Jul 2002
    Salem, OR
    You'll need to post more info. What format is the file and what are you trying to play it with?
  5. Guest
    read the first post, above
