HELP PLEASE!!!
When I try to view the avi file in the project wizard so that I can convert the source range I want ... all I see is blank .. the screen is black .. I check the properties of the avi file ... the video code is divxmpg4 v3 ... where can I get the codec for that? or I probably already have that codec since I can see the avi file in my media player... what do I have to adjust in TMPEG to be able to view that file ...
thanks ....
Have you tried using Virtual Dub to frameserve to TMPGEnc?
Hello. -
Did U try changing the priority settings?
A short derscription is given here
http://www.homepagemodules.de/board/topic.php?&board=1213&id=46801&forum=1860 -
Originally Posted by lilt
Select options > environmental settings
click the VFAPI plug-in tab
right click the "DirectShow" and select higher priority, do this several times until its at the top with a value of 4 -
The priority setting of Direct Show is already at 4 ... but it still doesn't help .. what should I do now?
http://nimo.everwicked.com/ http://perso.wanadoo.fr/nimo/ -
If you are able to open the movie in TEMPGEnc, you got the
right Codecs installed.
Try to run the complete movie instead.
And afterwards...open mpeg tool.
And cut out the part you want... -
Originally Posted by cramon
3.11 Alpha, DivX 4.8, but if its DivX 5 you get a black screen unless you have DivX 5
Pls Help convert my 3gp file to mpg or avi
By Nanflexal in forum Video ConversionReplies: 2Last Post: 1st Jun 2009, 15:58 -
View\convert\edit *.mpg file (mpeg2) with an Imac
By drastus in forum MacReplies: 3Last Post: 8th Feb 2009, 17:58 -
How can I convert MPG file recorded by progDVB into a regular MPG
By Aafour in forum DVB / IPTVReplies: 8Last Post: 16th Oct 2008, 13:51 -
How to convert an mpg file to avi
By spyros in forum Newbie / General discussionsReplies: 1Last Post: 9th Apr 2008, 15:02
