I have a couple Karaoke VCD that I wanna convert to SVCD because my APEX does not play Karaoke VCD. How would I do that?
a pretty plain question gets a pretty plain answer..
anyways im replying coz i got the same problem too before.. a vcd karaoke that i borrowed from my friend wont play on my APEX player too so i tried too look it up and browse the folders on my computer and the supposed to be xxx.dat file where all the karaoke songs are stored are no where to be found.. kinda cool and kinda weird too coz where did it go then? Anyways what i did is i try to make an image of the cd using CDRWin then convert the x.bin file to mpeg using VCDGear then burn using NERO.. everything went well after that.. =)
btw y wanna convert to SVCD.. i think its not worth it since your source is lower than ur wanted final output it might make a difference but i think it wont be that much... and i think ur APEX does play VCD i still have to see a same that doesnt..
The Apex player will play VCD but not Karaoke VCD cause it can't cut out the sound, but I does seperate the sounds in SVCD since SVCD carries stereo streams unlike VCD which has 2 mono audio line.
SVCD 2 DVD Not Working - Cant Add VTS or Click Convert
By rytech in forum SVCD2DVD & VOB2MPGReplies: 1Last Post: 2nd Feb 2010, 03:55 -
Can't convert avi to vcd, svcd etc...Failed Message
By shankbone in forum ffmpegX general discussionReplies: 2Last Post: 10th Oct 2009, 01:12 -
What is smpeg4 and is there a better way to convert then vcd?
By yoda313 in forum Video ConversionReplies: 12Last Post: 13th Mar 2009, 18:26 -
I have converted avi to vcd and svcd im looking to convert avi to dvd
By dbztoolkit in forum Newbie / General discussionsReplies: 1Last Post: 11th Jun 2007, 12:14 -
Convert NTSC AVI, DVD, (S)VCD to PAL DVD, (S)VCD
By scratchman in forum User guidesReplies: 14Last Post: 4th Jun 2007, 01:36
