Is there anything that wil allow me to go into a paint program and alter each clip. Meaning I want to edit each single frame. I know that will be a couple thousand of them. So how about it?
Any ideas
"Sleep-
Those little slices of Death;
How I loath them." -
You must extract your video as a series of stills first. Adobe Premiere can do this. It's explained in the help file.
I've actually done this. First I saved my short segment as a series of numbered TIFF images (I guess you could use JPG or another format just as easily). After that I edited them in Photoshop. Then I re-converted the TIFF images back to a AVI file which was then edited back into the original timeline. My image sequence was much shorter than 2000 frames---maybe 150 max, but it will work for as many as you have disc space for.
2000 frames is a lot of work. I hope you have a staff of animators.
Better Program?
By electrowiz in forum Newbie / General discussionsReplies: 1Last Post: 16th Mar 2011, 19:28 -
What's the name a program? unkown program
By Andrey81 in forum SubtitleReplies: 1Last Post: 26th Jan 2011, 13:04 -
MKV to AVI program, hardsubbing program, adding subtitle to DVD Flick
By projecttemp in forum Video ConversionReplies: 1Last Post: 21st Sep 2009, 09:42 -
A Program that can do all of this?
By Lord Balthazar in forum Authoring (DVD)Replies: 4Last Post: 15th Dec 2007, 12:13 -
What is the name of this program?
By innovyse in forum Newbie / General discussionsReplies: 2Last Post: 11th Nov 2007, 18:41
