Can some clever person tell me whether there is any difference in the picture quality between these 2 cards when capturinge from VHS cassetes to avi or mpeg format???????????
yes and no. all radeon cards use the Rage Theater capture chip. SOME AIW 128/128pro cards also use the Rage Theater chip. The quality of the rage theater picture has not changed in 3yrs, and the new capture drivers can be used on the older cards. however, SOME AIW 128s, predominantly the 16Mb PCI and some 32Mb PCI and 16Mb AGP come with a BT829 or BT878 capture chip, which does vary slightly in quality (it tends to be sharper in some cases, but i find it results in blockier realtime captures for that very reason).
They're relatively easy to distinguish. the Rage Theater will be a small square chip about 3/4" x 3/4" and say ATI Rage Theater across it and have some production codes. the BT chips will have a rockwell logo (similar to the atari symbol...). so even if you can't read it, you can see the graphic vs text difference in pictures on ebay and what not.
comparison between bluray and brrip
By xenotox in forum Blu-ray RippingReplies: 13Last Post: 24th May 2009, 15:17 -
Media type comparison.....
By sungator in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 1Last Post: 29th Mar 2009, 19:32 -
CL (in Ram) comparison
By Seeker47 in forum ComputerReplies: 3Last Post: 20th Jan 2009, 15:01 -
Comparison Chart of Over 40 HD Cameras
By Gary Roberts in forum DVB / IPTVReplies: 0Last Post: 17th Dec 2008, 09:32 -
vcr's in a chain to see the comparison
By victoriabears in forum Newbie / General discussionsReplies: 7Last Post: 30th Jun 2008, 18:10
