i tried to burn my first vcs yesterday using the newbie guide but when i statted to encode using TMPeg the remaining timewas 67 hours. is there a faster way or is it possible to encode the vobs at different times then join them togather if so can you please help
As you didn't mention what settings you are using it is difficult to say what the normal time would be for encoding - also the processor you are using is of importance here.
You can however either use the original VOB files or if you want to make them even smaller use a program called VOB Utils which will devide the VOB's into chapter VOB's. These you could seperately encode into mpg's and later merge together - so it's all up to you.
Help me, I'm a newbie
By Shadowmistress in forum Off topicReplies: 2Last Post: 19th Jun 2011, 07:54 -
Hello from Newbie
By markwaugh in forum Newbie / General discussionsReplies: 4Last Post: 11th Apr 2011, 12:13 -
Newbie needs help!!!!!! DVD to xbox 360 streaming
By JohnS719 in forum Newbie / General discussionsReplies: 0Last Post: 22nd May 2010, 07:38 -
You want newbie? This is newbie. Watch VHS movies.
By Mighty Melvin in forum Newbie / General discussionsReplies: 14Last Post: 12th Oct 2009, 08:43 -
MUX Help (newbie)
By thisisjontheman in forum ffmpegX general discussionReplies: 2Last Post: 19th Oct 2008, 08:52
