  1. Sometimes when i try to convert avi to mpeg to make a vcd, the playback color is distorted. It would become a little reddish and change back to normal. This would happen every couple of seconds. I use Tmpgenc to convert. Any ideas??
  2. Banned
    Jun 2001
    UK
    What is the original file like ?, If you have the SMR (Angel portion) codec installed... Get rid of it
    TMPGEnc
    Select options > environmental settings
    click the VFAPI plug-in tab
    right click the "DirectShow" and select higher priority, do this several times until its at the top with a value of 4
  3. What codec should we use instead???
  4. Banned
    Jun 2001
    UK
    For converting with TMPGEnc you need to use the codec that the original was converted into What ever that may be.
    You don’t choose one, it will automatically use the right one... Provided you have it installed. The Nimo codec pack will provide the most popular ones. You only need to install them all, for them to be used automatically.
    Its only when you want to convert to a MPEG 4 type that you would need to choose a codec.
    http://nimo.everwicked.com/ http://perso.wanadoo.fr/nimo/
