Hi,
I'm having a problem reducing the number of cd's i use when creating an svcd. THe thing is I have a 136min movie that i want to fit into 3 cd's (as a friend of a friend was able to do for a 140min movie) but it always ends up in four volumes. The program that I am using to encode the VOB is DVDx v2.0. Could you tell me what settings i should use to reduce the size or, if there is one, a better programe out there that could help me with this dilema. Thankyou for your time!
	DVDx is a good appp try lowering the bitrate and remeber 800mb file fits on 80 min disc and 74 74 min disc. so lower bitrate until estimated size is 2400. mb (because 3X80min = 2400) then click the option that says something like don't let volume exceed 80 min vcd.
 I realize Im not the best at explaining hope this helps
	DVD2SVCD is wonderful for setting the number of discs based on movie length. It is an all in one rip package, but you must install either TMPGEnc or CCE (recommend CCE highly) for the encoding and tell DVD2SVCD where it is. There are plenty of tutorials out there.
  In plasma TV "Number of pixels" and "Number of dots" it's not a same term?By flash_os in forum Newbie / General discussionsReplies: 2Last Post: 23rd Aug 2011, 13:27
  ffmpeg Number of stream maps must match number of output streamsBy tmiller_15 in forum Blu-ray RippingReplies: 1Last Post: 13th Nov 2010, 07:20
  4:3 to 16:9 without reducing qualityBy trickytree in forum ffmpegX general discussionReplies: 2Last Post: 3rd Jun 2009, 19:06
  Reducing filesizeBy caper in forum Video ConversionReplies: 19Last Post: 7th Dec 2008, 20:22
  Help with reducing sizeBy gepetto in forum Newbie / General discussionsReplies: 3Last Post: 13th Nov 2007, 14:17
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
