I'm converting some tv eps (avi). They convert with tmpg no problem (48khz, 160kbps), and play just fine. But when I burn them (vcdeasy) and play them, the audio drops out every few seconds, like it's muting. I've tried it in 2 different model apex players. Any suggestions?
Actually, it doesn't seem to go completely silent, just drops real low. This just kills me. It took me a ton of test burns to finally get menus down pat, now this. And it never happened before now. I've tried different movies, always the same thing. Any help appriciated.
VCD ? 44.1Khz have you tried using the audio separated when converting with TMPGEnc
You mean demux and then put them back together? No, but I can try. Also, do you think it could be because it's not at 44.1?
48 k audio is only used on dvd... for (x)(S)VCD always use 44.1 and keep an eye on the total bitrate...video + audio...must be within specs.
Originally Posted by LucasBuck
VCD spec says that it should be 44.1Khz if some how you did get 48Khz on the disk, this alone would probably cause your problem.
It does sound like you skipped the check in Vdub, you would normally use that to extract the audio to a uncompressed WAV at 44.1Khz then when that is used with TMPGEnc there is little chance of problems with the audio.
At the same time, 48Khz makes me think you may even have AC3, so you would need "Vdub AC3" if it does have it.
Don’t know if you can rescue the mpeg you already made, might be worth trying, TMPGEnc can also save out the audio, but what ever method you choose, use 44.1Khz and uncompressed to be safe.
Multiavchd used & audio choppy
By jbitakis in forum Authoring (Blu-ray)Replies: 9Last Post: 2nd Dec 2011, 20:38 -
WMP11 wont play some MKV files-problem (choppy audio output only)
By deejay.2001 in forum Software PlayingReplies: 4Last Post: 31st Jul 2009, 07:09 -
Can you solve my choppy video problem?
By imrealdumb in forum Newbie / General discussionsReplies: 2Last Post: 4th Jun 2009, 20:44 -
Fast/Choppy Audio on Divx
By bassmaniu in forum AudioReplies: 3Last Post: 24th Jan 2008, 12:42 -
TS audio playback is choppy
By autumnwillow in forum Newbie / General discussionsReplies: 5Last Post: 12th Nov 2007, 09:14
