#1---Used TMPG Rnc to encode am avi to mpg--when i go to burn through Roxio 5.0 VideoCD says it cannot burn.??????????????
#2---Can I use my computer while converting avi to mpg--it is a long process?????????
#3---Alot of avi movies I have wont show up when I load them in TMPG????????????????????
I have a 1Gig Speed 384Ram---and have tried 4 or 5 programs now--including LSX-mpeg--Roxio Conversion--TMPG---Avi2vcd
Thanks for the time!!!!!!!!!!!
Bill
1) Roxio requires a fully compatible VideoCD format, have you remembered to load a VideoCD Template in TMPGEnc AFTER you opened your file for encoding ?
2) You can use your computer while encoding, but this will make the process even longer.
3) An AVI isn't just an AVI, it can be encoded with strange codecs, some are familiar to TMPGEnc and it can open them (MJPEG/DivX for example) and some have unknown codecs and it cannot open them.
Email me for faster replies!
Best Regards,
Sefy Levy,
Certified Computer Technician.
Help me, I'm a newbie
By Shadowmistress in forum Off topicReplies: 2Last Post: 19th Jun 2011, 07:54 -
Hello from Newbie
By markwaugh in forum Newbie / General discussionsReplies: 4Last Post: 11th Apr 2011, 12:13 -
Should I Get An HD Camcorder? (Newbie)
By davebo in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 18Last Post: 21st Jan 2011, 03:48 -
Newbie needs help!!!!!! DVD to xbox 360 streaming
By JohnS719 in forum Newbie / General discussionsReplies: 0Last Post: 22nd May 2010, 07:38 -
You want newbie? This is newbie. Watch VHS movies.
By Mighty Melvin in forum Newbie / General discussionsReplies: 14Last Post: 12th Oct 2009, 08:43
