I just encoding 3 parts of a tv show to same format and same options and whenever i try to join them together it always says that one or the other is not compatible format with one or another, any idea on how to fix this problem?
If your captures are slightly different even by 0.01 Fps it can throw TMPGEnc, not very nice
Tracking the difference and correcting it would avoid re-encoding, but that may be difficult.
The quickest would be to re-encode each one to perhaps a VCD template, then merge later.
You could try the Merge & cut on each one, but simply do another copy with each one, not using any source rage.
Problem merging video clips and suggestion on best tool?
By nerys in forum EditingReplies: 1Last Post: 18th May 2011, 00:41 -
Problem merging 2 MKV's
By nutman in forum Video ConversionReplies: 3Last Post: 7th Dec 2010, 09:31 -
Problem in merging splitted AVI files of a movie into one.
By nick2712 in forum Newbie / General discussionsReplies: 8Last Post: 2nd Oct 2010, 14:20 -
MKV merging help
By snadge in forum Video ConversionReplies: 0Last Post: 25th Oct 2009, 13:19 -
BIG Problem TMPGENC Xpress V.4.4.1.237 + TMPGEnc DVD Author ver.3.1.2.176
By milindb1 in forum Authoring (DVD)Replies: 1Last Post: 20th Aug 2008, 02:41
