Hi.
I had problem with a vcd, that is in 2 cds, and i wanted to reencode it with a lower bitrate to fit in one Cd, but, TMPGEnc doesnt recognize it!
i tried both, direct from the cd, and converting it mpg with a vcdeasy tool.
but vcdeasy also cannot read it! It plays well in my standalone dvd.
I think it was burned in windows 95, or something like that. the las modification date is xx/xx/1999
so?
If it was burned in a old windows, how to reencode it in win2000??
help!
tks
Hi,
See my message-post in http://forum.vcdhelp.com/viewtopic.php?t=107035
Don't use VCDgear. It's terrible (read it in the post : "why" and a "sollution").
As soon you've got your MPeG, you should use VDub to de-encode the mpeg to an AVI again (using whatever codec you prefer).
If the mpeg's were SVCD, it won't work in VDub. Then you should use FlaskMpeg (the app directly). FlaskMpeg can reconvert the MPeG (not the DAT) to an AVI (same like in VDub).
VDub is easy and faster but only for MPeG-1, while FlaskMpeg also supports MPeG-2
cu.
Reencode
By mentme33 in forum Newbie / General discussionsReplies: 9Last Post: 17th Dec 2010, 13:08 -
Win95, Win98 and WinXP
By Jomapil in forum ComputerReplies: 9Last Post: 4th May 2009, 13:41 -
installing win95 on hd that has xp
By mac71671 in forum ComputerReplies: 15Last Post: 18th Feb 2009, 20:08 -
Remember your desktop icon layout for WIN XP..like win95 ezdesk? [RESOLVED]
By vhelp in forum ComputerReplies: 6Last Post: 7th Jan 2009, 10:22 -
DivX reencode
By Ogilvy in forum LinuxReplies: 1Last Post: 3rd Jul 2008, 14:17
