What does it mean when you use Fireburner to try and burn bin and cue file and it says "floating point zero"
blacjac27,
The error is coming from the Fireburner software (I am not familier with that sw. I use NERO).
It indicates either bin/cue file was corrupt/damaged or the Fireburner software does not like something in the file. Try another set of bin/cue files.
If the error is coming when you are trying to create the bin/cue file then the input to the Fireburner is suspect. Try different set of files to Fireburner.
Robert
cue and bin files
By natty in forum Newbie / General discussionsReplies: 2Last Post: 21st Jun 2011, 15:25 -
Having trouble with .bin/.cue files
By UncleBose in forum Software PlayingReplies: 8Last Post: 12th Jan 2008, 06:06 -
cue,bin converting to dvd?
By zziem in forum Newbie / General discussionsReplies: 5Last Post: 7th Aug 2007, 10:36 -
What files/settings do I need for bin/cue
By Choppa in forum Authoring (VCD/SVCD)Replies: 9Last Post: 23rd Jun 2007, 21:29 -
How to merge 2 cue/bin to one DVD
By motleycool in forum Newbie / General discussionsReplies: 5Last Post: 7th Jun 2007, 21:26
