CAN ANYONE TELL ME HOW TO FIT 90 MINUTES ON A VCD. IT SURE WOULD HELP ME OUT A GREAT DEAL. LATELY, CAN ONLY GET 65-70 MINUTES
1. please do not shout (using all cap's = shouting)
2. You do not state what encoder you are using? tmpgenc,ligos,procoder,cce,ulead,panasonic..etc?
3. if using tmpgenc, try the templates listed in the tools
section (left hand side, near bottom of this website)
and look at Sefy's templates. They will do 90 minutes
for you at ok quality although you will be creating
a xvcd or sxvcd (ie. non standard vcd). Also check
out the KVCD templates as some ppl like these also. -
Remember that when you do that you will not have a standard compliance VCD (it will be an XVCD). Unless you get 90 or 99 minute cd's... You should probably stick with the XVCD solution if they play on your standalone...
I've found that KWAG's templates give great quality while getting 85 minutes + on an 80 minute CD-R
Hope this helps!Big_Jit
Change length of an AVI. Reduce/Increase Frame Length
By Buzwinkle in forum Authoring (DVD)Replies: 4Last Post: 10th Aug 2011, 08:08 -
Clip Length Changing?
By Problematique in forum ffmpegX general discussionReplies: 1Last Post: 18th Nov 2009, 14:26 -
Burning vcd/svcd full length film.........
By marcgarcia in forum Authoring (VCD/SVCD)Replies: 2Last Post: 15th Oct 2007, 20:07 -
time length
By zoobie in forum Newbie / General discussionsReplies: 4Last Post: 29th Jun 2007, 15:40 -
VCD to DVD (TDA error: GOP too long)
By jelir in forum Authoring (DVD)Replies: 1Last Post: 6th Jun 2007, 09:40
