i am trying to make a vcd of monsters inc off an divx movie but every time i set it up with a vcd template it encodes the movie faster than the progress bar ,something like the movie finishes at around 40% then goes blank why is this
i did check the framerate of the divx movie which was 23 fps so thats what i changed the TMPGEnc settings to to keep the audio in sync
am i doing something wrong?
If you have all the movie at 40%, then load back in to TMPGEnc merge/cut got to the end of the movie, if the frames are the same at the end, use the source rage to save out just the movie.
First check the AVI for junk frames with Vdub
After splitting and combining with AVIdemux, progress bar goes on after end
By johnharlin in forum EditingReplies: 3Last Post: 21st Oct 2010, 04:40 -
ffmpegX only encodes warning at beginning of movie
By kgplumb in forum ffmpegX general discussionReplies: 2Last Post: 29th Aug 2010, 08:07 -
Older FFmpeg encodes MUCH Faster than newer builds!?
By V1de0Luvr in forum Video ConversionReplies: 4Last Post: 25th Nov 2009, 07:33 -
Windows Media Player: MPG playback bar moves faster than video plays
By Grunberg in forum Newbie / General discussionsReplies: 4Last Post: 15th Sep 2009, 04:07 -
TMPGEnc encodes to 1%, then my PC restarts
By Syntax in forum ComputerReplies: 3Last Post: 5th Jul 2007, 16:18
