Hi everyone, I have a small question to ask. What compressor/codec should I use after capturing and editing the video? I don't use any compressor when capturing but sometimes the video is long and when I edit it, I want to save it but I don't know if I should use any compressor. I want the vido to be high quality, but I also don't want it to take up much space. For example, what should I do if I want to put 44mins of video on one 74min CD? What compressor should I use when and after capturing the video? I hope you understant what I'm saying coz at the moment I can't think a lot as it is 1:30am.
I dont think we can give you an answer until we understand if you want to watch it on a DVD player or just watch it from a coputer.
If you only want it to fit on a cdr so you can watch it on other computers I would suggest DivX
with a higher bitrate than the default.
If you want to watch it on a DVD player then your only real choices are MPEG-1 or MPEG-2 ...but make sure your DVD player will play VCD's first -
Well, I want to watch it on computer, but as I said before, I want the quality to be good. I don't like when I see big pixels on the screen.
What is the best compressor to use???
By BobAchgill in forum EditingReplies: 7Last Post: 13th Sep 2011, 07:55 -
Compressor gives me .h264, but....
By whoisquilty in forum MacReplies: 4Last Post: 10th Jan 2011, 12:38 -
About good video file compressor tool
By coody in forum Video ConversionReplies: 2Last Post: 5th Jan 2011, 15:49 -
regarding VP video compressor
By liddu in forum Newbie / General discussionsReplies: 6Last Post: 14th Jul 2007, 09:15 -
Why is compressor lying to me??
By whiff79 in forum MacReplies: 2Last Post: 4th Jun 2007, 15:38
