I have produced SVCD compliant MPEG-2s frameserving from premiere 6.0 with the videoserver plugin to TMPGenc and also encoded a similar file directly with the LSX premiere plugin. The source material was premiere captured DV. The MPEG files look good (the TMPGenc far superior to the LSX) with no flicker but when I burn the files and play them on my standalone the top third of the screen flickers. My standalone is toshiba SD-220E, I have had no problems playing other SVCDs on it (although this is the first time that they are DV source files).
I have tried burning with Nero (5.5.9) and DVD workshop (1.2) as well as reducing the burning speed and trying different media - all to no avail. Also I created a VCD (panasonic premiere plugin) from the same material which did not have the same flicker. Can anyone suggest what is going wrong and how can I rectify it, thanks in advance, Dom.
Your field order is wrong. Switch between field A (upper) and field B (lower) should fix it.
I tried switching field order, as well as trying deinterlaced neither got rid of the problem. The MPEG files look great on the PC and apart from the flickering look superb. The problem has happened with SVCDs encoded from two different DV camcorders, on one the top part of the screen flickered, on the other the bottom. I am now most confused, any further help would be gratefully received, Dom.
film from imovie pixalating in top 1/3 of screen
By settera in forum MacReplies: 4Last Post: 3rd Apr 2009, 08:40 -
PAL to NTSC renders OK on top of picture, flickers on bottom half
By Exiled_Brit in forum Video ConversionReplies: 6Last Post: 21st Sep 2008, 14:31 -
Distortion at the top of the screen with VHS capture
By Ninjafish in forum Capturing and VCRReplies: 7Last Post: 26th Mar 2008, 15:45 -
Screen flickers after updating my Asus BIOS
By Hittz in forum ComputerReplies: 8Last Post: 18th Feb 2008, 01:38 -
Distortion at top of screen
By Theresa in forum RestorationReplies: 30Last Post: 17th Dec 2007, 03:35
