Someone who could tell me how to do?
I know, using Avisynt It coud be possibly to open
svcd's in V-dub. But i I lost my text file, describing
"How to".
You make a' "Fake" text file. Showing where
your svcd are located at your disk. C:\ Movies\Matrix.mpg
for example. And save it as? Or rename it XXX.avi ?
Then you open the fake avi? file in V-dub.
Guide Please....Or tell me how..![]()
I found the solotuion in Doom9's forum.
Now it works....
Yes, i tried TEMPGENc...but the audio gets out
of sync..
And I'm going to add subtitles in V-dub, in the svcd. Framesrving to
TEMPGENC... -
Yepp, I know
But I think i drop the whole Project.. He he. And DownL an avi
Instead.
I made a' .d2v file in DVD2AVI....created a txt file. With info
about where my SVCD vere located. Renamed it .avs.
LoadPlugin("C:\Windows\system32\mpeg2dec.dll")
mpeg2source("D:\temp\AVSEQ01 MPA .d2v")
Bob
Opened the avs (Svcd) in V-Dub. Added wav file as sound
and saved it as Avi DivX5.1
But the Avi output wasn't, perfect. :
Fast movement became unsharp. And some edges of Objects also.
If you know what I mean..
(Bad English.. He he )
I'm giving it one more try. I added the row Bob in the
script. This will fix all interlaced files that look corrupted.
If thats My problem... Or maybe some ntsc/Pal problem? Framerate? -
No it was MiB 10....
It's just fun to learn new stuff...programs. And so.
BtW...I finnished the movie now.
(D-L a' avi..A lot easier..He he)
Need help with Virtual Dub setting
By lost123 in forum Capturing and VCRReplies: 12Last Post: 8th Jul 2010, 21:31 -
Virtual dub
By santolina in forum Newbie / General discussionsReplies: 4Last Post: 22nd Jul 2009, 13:48 -
Problem with AVS file to open correctly in virtual dub and encode.
By vck in forum Video ConversionReplies: 9Last Post: 15th Aug 2008, 09:27 -
help with virtual dub
By Remyisme in forum Newbie / General discussionsReplies: 7Last Post: 30th Jan 2008, 15:36 -
Virtual Dub Mod
By OG24 in forum Newbie / General discussionsReplies: 11Last Post: 8th Aug 2007, 15:36
