  1. when I try to do a 2-pass the end product plays on my dvd (mustek)
    but wont play on my sons or his mates1 a sony the other a cheep tescos one that seems to play everything else.
    My question is am I doing something wrong?
    In tmpeg I load the standard pal template then load the unlock one in the extra folder and change the video setting to 2-pass
    then start encoding
    Should i do something else?
    also could somone advise me what is the best aspect ratio to use
    full screen / full screen keep aspect ect
    thanks for any advice
  2. the vcd standard requires CBR at 1150kbs, 224 audio. 2 pass might
    not work as this creates a variable bit rate which some players don't like.
    Stick to CBR (constant bit rate) at 1150 or CQ at 1150.
    (tmpgenc 2 pass at defaut vcd bitrates is a waste of time anyway, those that use two pass usually set the maximum bitrate quite high)
    May 2002
    Rainy City, England
    Although it does not produce a standard compliant VCD, you can use 2-pass VBR (or CQ) and limit the max bitrate to 1150kbps, but set the min. bitrate to 300.
    You should always choose a video arrange method that involves *keep aspect ratio* if you want to keep the aspect ratio. Usually, the best choice is full screen (keep aspect ratio).
