I saw somewhere that their is software you can download that will identify the manufacturer of cd and dvd discs. I cannot find it again however and was wondering if anyone knew of where I could get it to test some dvd-r's I just purchased ? I am trying to find out from where the best dvd-r's come from for my setup. Their seems to be alot of confusion with all the marketed brands of blank media and I was just hoping to narrow that by identifying just the manufacturers. Thanks in advance.
Ok, I found ADVDINFO. but I get a "Could Not Detect A DVD-ROM !" error. I have a Pioneer DVR-A04 writer on the Primary Slave IDE, and the drive works fine and shows under device manager using Windows XP Prof, but still ADVDINFO does not detect a DVD Drive.
Anyone know of any solutions or a different utility ? -
I dumped all the ASPI .sys files into its directory and it works fine for me.
Flaystus, what OS are you using ?
I dumped the ASPI. sys files in the directory and it recognizes the drive now but I get a "Cannot Create Device List" error...... I am using WinXP Pro. -
XP Pro here also... hrmm... some people are having issues and others not. Very picky software. When I get home tonight I'll make sure and see if there was anything else I changed.
advdinfo will display the prerecorded information in the lead-in. Unfortunately this isn't a reliable indicator of quality as many brands display exactly the same header.Originally Posted by Don2050
Same header, different something else (dye/quality/batch/OEM specification?)
I did this recently with as many discs as I could get my hands on, burning the same test disc and trying it on as many players as I could find. If you're interested in my results, let me know.
Wanting more info on video rendering and creation software
By spiralthinker in forum Newbie / General discussionsReplies: 6Last Post: 11th Jan 2011, 14:51 -
Question why I can't install this DVD player software
By jimdagys in forum ComputerReplies: 3Last Post: 11th Oct 2009, 18:42 -
Playout software for info TV
By mivari in forum Software PlayingReplies: 0Last Post: 12th Sep 2009, 09:11 -
question about where bad hard drive disk sector info is stored
By jimdagys in forum ComputerReplies: 1Last Post: 20th Apr 2008, 17:24 -
Software to view technical info of dvd video
By cengoh in forum Software PlayingReplies: 3Last Post: 28th Sep 2007, 04:59
