I have an occasional stuttering problem when converting divx to SVCD using TMPGEnc. I think I've narrowed down the problem the DIVX was 23.97 FPS but when converting to MPEG under SVCD I believe it forces 29.97. I am unsure as to whether or not the FPS difference would cause stutters the max bit rate is 2496, avg bitrate is 2496, and min bitrate is 1000 and I am using the RCA 5240P which has the ability to play higher bitrate so I don't believe it's a bitrate problem. I used Biterate Viewer and the biterate never went below 1700. Any suggestions or ideas?
I guess it's my player because I tested the in the downstairs Samsung 1000V and no stutters. I have a bunch of downloaded SVCDs and this is the only one that stutters on playback and i have no idea why?
no still get stutters with CBR but only 2 for a 48 minute clip I continue to mess with settings.
What speed are you burning at?? I get beter luck when I burn at 10x and under!! just a thoguht
true i was burning at 48 for all my burns but I decided to lower it to 32X for VCDs and SVCDs i'll try and go down furthe, thanks for the suggestion.
Choppy/stuttering ac-3 playback using HDMI!
By Anonymous5394 in forum Newbie / General discussionsReplies: 0Last Post: 11th Jun 2010, 11:08 -
.hs64 stuttering playback
By realdanielh in forum ffmpegX general discussionReplies: 1Last Post: 28th Aug 2009, 14:26 -
HD Content Stuttering on Playback
By Foxfire 1 in forum Software PlayingReplies: 4Last Post: 3rd Aug 2009, 06:56 -
Stuttering Playback on 1920 x 1080 WMV files
By thebazman in forum Software PlayingReplies: 18Last Post: 31st Aug 2008, 08:17 -
Stuttering during playback of Bluray from HDD
By aye29 in forum Newbie / General discussionsReplies: 1Last Post: 22nd Dec 2007, 01:54
