  1. hi i'm converting a movie with tmpgenc i've done it lots of times before, but this time the movie was done encoding around 50% and now its still has about 150 thousand fames lift but the movie is done.
    Does anybody know why.
  2. Член BJ_M's Avatar
    Jul 2002
    Canada
    any space left on your hard drive ?
  3. Are you using the latest version of TMPGenc ?
    You can always make a note of the frame where it stopped encoding, then start encoding again from that point on (Click on settings, go to the advanced tab and double click on source range). You can then join the two files together using the Merge&Cut function (File, MPEG Tools)
    Hope this helps
    Olli
  4. Originally Posted by BJ_M
    i only have 1 gig left is this the reason why
  5. Член BJ_M's Avatar
    Jul 2002
    Canada
    i would say its a major factor -- as when you are down to the last gig .. the amount may not be reported correct and whats left is prob pretty frag'd
