I've been trying to do it with "DVD-Copy" of NERO but when i navigate in the menus, it hangs. ( In the PC & the DVD PLayer too ).
I check the properties of the original DVD and it says :
type : CDFS
the copy says: RAW
is ovious that the copy is wrong.
Why is this ?
How can i make a perfect copy from a DVD to DVD ?
i'm trying to duplicate the "Time out with britney spears" is around 4.1 GB.
thanks
Download Smartripper, rip the movie to your HD, then burn all the files back with Nero's DVD-Video template.
When using Smartripper, choose the copy VOB option. You want to grab the whole disc (menus), not just the movie/dance numbers. -
As Churchill famously predicted when Chamberlain returned from Munich proclaiming peace in his time: "You were given the choice between war and dishonor. You chose dishonor, and you will have war."
Duplicate Non-Protected DVD+RW onto DVD-R
By rsatria in forum MacReplies: 2Last Post: 24th Nov 2011, 14:28 -
Easy Question..Make duplicate of movie DVD
By WareISChris36 in forum DVD RippingReplies: 4Last Post: 23rd Jul 2011, 15:43 -
Duplicate a DVD....can you simply copy Audio_TS folder and Video_TS folders
By True Colors in forum Authoring (DVD)Replies: 6Last Post: 29th Apr 2010, 15:37 -
Duplicate DVD to editable DVD+RW on a Toshiba D-R410KU
By Rick K in forum Authoring (DVD)Replies: 2Last Post: 30th Apr 2009, 21:31 -
Burning HD to normal DVD + other questions
By Gaelstrom in forum Authoring (DVD)Replies: 4Last Post: 30th Oct 2007, 18:02
