I d/l this file, but when I go to load it a message comes up saying, "Error loading TMPGEnc.vfp, the specified module could not be found."
I couldn't find anything in the help section about this problem, and I need this plug in to use tmpgence properly. Anyone had this happen before or know what I should do?
When you download the plug-in there are 3 files
TMPGEnc.vfp (The plug-in)
TMPGEncVFP_Install.bat
TMPGEncVFP_Uninstall.bat
They all must be in the route folder of TMPGEnc before you run the install.
The download is a zip file, open it up, select all the files and drop into TMPGEnc folder
problems going from quicktime mac file to usable pc file
By pjcom in forum Video ConversionReplies: 11Last Post: 19th Apr 2010, 13:49 -
Tmpgenc 4 plug-in settings cant be changed?
By mrjust in forum Newbie / General discussionsReplies: 0Last Post: 27th Mar 2010, 22:50 -
Problems with TMPGEnc...
By SolsBBQ in forum Video ConversionReplies: 5Last Post: 3rd Jan 2009, 06:00 -
TMPGenc DVD Author 3 will not open file from TMPGenc Xpress 4.0
By artyjeffrey in forum Authoring (DVD)Replies: 4Last Post: 8th Nov 2008, 13:23 -
Problems with TMPGENC 4.0 XPRESS + TMPGENC DVDAUTHOR 3.0 :( help
By neurosys in forum Authoring (DVD)Replies: 3Last Post: 10th Aug 2008, 18:37
