  1. Just used Easy CD Creator 5 Platinum to burn a MP3 music CD.
    When inserted into my Toshiba SD900 player the disc loads and shows that there is 1 hours plus of audio but when I press play nothing happens. The play icon shows as playing but there is no audio and the counter remains at 00-00-00.
    Anyone else had the same sort of problem? Or recommend other software to try?
    Ondy
  2. If its just an Audio CD you want to compile a piece of software I would highly recommend is Music Match Jukebox and its so easy to use.
    Regardsatsym1
  3. Just want to know: Is it an Audio Disc or mp3 files?
  4. Otomone
    I am trying to burn mp3's. I can burn normal audio CD's. But my player can play MP3 CD's (I think it recognises the M3U playlist file).
    Ondy
  5. Otomone
    Ondy
    Jul 2001
    Maryland
    To burn MP3's to play in a CD/DVD player that caries the "MP3" mark. These will remain in MP3 format and require an MP3 decompressor, found only in 4 CD player but more in DVD.
    Simply burn a DAO Data CD.
    Apr 2001
    Are you sure it's that easy?
    On my Apex (which supports mp3), I popped in an old mp3 cd I had, and only 8 files showed up. All 8 played fine, but this is 8 that showed up of 150 files!
    Is there some typical structure to use, or is the most important thing DAO? (closing the CD?)
