The copy of Odyssey 5 I recorded from Showtime last week is screwed up. File size is about 2GB (about right for a 45 minute show recorded in high quality mode, VBR 6000 kbps, on my ReplayTV), but both DVD Workshop and Womble MPEG2VCR show the file as only lasting 10 minutes and won't play it past the ten minute mark.
I know the whole episode is there, because it's the exact same file size as the previous episodes. How can I re-encode this thing so one of those two programs sees the rest of the episode????
Thanks...
If you captured in MPEG-1, you may be able to load it into Virtual Dub and scan for vieo stream errors.
Hello. -
Try running it thru VCDgear with MPEG to MPEG selected and with FIX MPG ERRORS checked. This has worked for me on files that TMPGEnc choked on.
Originally Posted by Tommyknocker
Originally Posted by circleking
Sorry, I forgot to point you to VCDgear. There are links to it in the TOOLS section under REPAIR/CONVERTERS.
Thanks...
Trying to fix an mkv file
By mkr10001 in forum Video ConversionReplies: 4Last Post: 17th Oct 2011, 15:46 -
mpeg2 ts file convert to mkv or mpeg2 ts......change only video bitrate...
By jrblack in forum Video ConversionReplies: 4Last Post: 24th Jan 2011, 18:45 -
No audio track when importing mpeg2 into sony vegas? How do I fix this?
By bojadada in forum Newbie / General discussionsReplies: 1Last Post: 28th Nov 2009, 10:53 -
convert hd pal mpeg2 file to hd ntsc mpeg2 file
By gearo in forum SVCD2DVD & VOB2MPGReplies: 8Last Post: 5th Jun 2008, 01:12 -
how to fix a corrupted file?
By sharmine in forum Newbie / General discussionsReplies: 4Last Post: 25th Sep 2007, 17:03
