Hi guys.
What happened:
After I did some changes to the Xvid four CC changer values, I can't play my .avi files anymore.
My failed attempt:
I have tried uninstalled Xvid, delete registry keys of Xvid but I still can't play .avi files. I also tried re-installing all my divx codecs but it didn't work.
My problem:
Windows Media player 6.4 and 8.0 will just freeze and I need to force quit the application. I can't view my beloved avi files anymore.
Pleaseeee... anyone can help me?
Format C: will be the last resort and I don't want to habour that evil thought.![]()
did you change the four CC values of the file or was this a setting for something else? -- because the four CC bits is used as an identifier for certain type avi files ... and i would think changing them would be a big no no if you didnt know what you were doing ,, i don't know the values either but i see big warning on a program i have saying changing these values will make this file unplayable ... can you set them back to what they were?
Yes, I changed the settings..
How can I get back the xvid default settings? i tried uninstalling xvid and deleting the registry keys of vxid, but nothing work.
I tried that many times. I even went to registry and delete xvid keys. But it still doesn't play .avi files anymore.
Install the Nimo codec pack, see if that fixes the problem. Can you load AVI's into Vdub ?
Best way to batch convert xvid/avi files to mkv/x264 files?
By gaikokujinkyofusho in forum Video ConversionReplies: 1Last Post: 13th Jan 2012, 07:31 -
Join Avi (xvid) files together
By SpyJoe in forum EditingReplies: 11Last Post: 26th Aug 2009, 18:44 -
burning .avi and xvid files to DVD
By neviller in forum Video ConversionReplies: 3Last Post: 13th May 2009, 15:41 -
Ok no Need for 4CC Changer for Vegas to Import Xvid/Divx fig
By canadateck in forum User guidesReplies: 11Last Post: 18th Sep 2008, 13:21 -
Help with re-encoding avi files (XviD/DivX)
By noskid21 in forum Newbie / General discussionsReplies: 2Last Post: 18th Aug 2007, 15:24
