Hi,
I have been working for a long time. I have read a lot of those howto, but I can not create a non standard VCD or SVCD.
I use MediaPipe (a great program). Every people says that when you use the -q option in mpeg2enc, you are using VBR. Ok, but if I use -f1 (standard VCD) or -f4 (standard SVCD) I have seen that I can not obtain lower or higher bitrates than the standard.
I thought the solution was not difficult: I can use -f2 or -f5 (user VCD/SVCD). It goes well and I obtain the file size I expect with my bitrate ... but I can not make an image.
I've tried with MissingMpegTools:
* mplex can not multiplex a non standard VCD/SVCD (only in terminal)
* vcdxbuild can not make an image if I give it a non standard VCD-SVCD (really it makes it, but it is not good: my movie is 15 Mb and the image has a few kilobytes)
Somebody can help me, please...
Results 1 to 1 of 1
VCD to DVD (not SVCD)
By noyou in forum SVCD2DVD & VOB2MPGReplies: 20Last Post: 19th May 2009, 17:56 -
Final Cut Express 4 can I create chapters for a DVD I create
By Jabroni4872 in forum MacReplies: 1Last Post: 18th May 2008, 12:36 -
Beeping on vcd/svcd
By mgdt in forum Newbie / General discussionsReplies: 5Last Post: 20th Dec 2007, 11:56 -
avi to vcd/svcd
By neynme in forum DVD RippingReplies: 7Last Post: 26th Aug 2007, 21:25 -
how to create VCD protection?
By C-W in forum Authoring (VCD/SVCD)Replies: 4Last Post: 18th May 2007, 13:00
