I created two CVDs from a single .AVI is order to skip a part that I didn't want. I created the .mpg files with the ADVANCE/SOURCE RANGE function of TMPGEnc then joined them with the MPEG Tools/Merge & Cut function. The audio from the first file was about 10 seconds longer than the video. This threw the audio out of sequence with the video on the second file joined to the first. What is the best way to correct this problem?
The procedure usually calls for you get a a copy of your audio, "compress" the audio so that it matches your video. It is one of my favorite functions in Gold Wave (the Time Warp function).
Then make a new video using the old video and the newly compressed audio to make new video containing properly synched audio and video.
http://forum.vcdhelp.com/userguides/78944.phpHello.
TMPGEnc Video Master Works audio problem creating bd25
By necron99 in forum Video ConversionReplies: 0Last Post: 29th Apr 2012, 20:52 -
AutoGK problem 'No video sequence header found'
By Sneblot in forum Video ConversionReplies: 2Last Post: 11th Jun 2011, 12:23 -
TMPGenc Audio Problem
By Iwan2learn in forum Authoring (DVD)Replies: 5Last Post: 13th May 2009, 10:27 -
Audio Problem using AVISynth and TMPGEnc Xpress
By 1980sumthin in forum Video ConversionReplies: 10Last Post: 27th Jan 2009, 06:27 -
AVC/h264 1080p mkv macroblock problem on sequence transition
By djesteban in forum Blu-ray RippingReplies: 23Last Post: 7th Oct 2008, 10:18
