Can anyone help me with a guide how to delete bad frames on avi files using virtual dub or another simular program... Because when i frameserve with virtual to tmpeg-encoder some movies crash and when i check for bad frames it tells me witch ones are bad, but my problem is i cant delete them... sorry for my english, im very tired at the moment
Once you have checked for bad frames in vdub, just save as an avi file with a different name. It will resave the file without the bad frames.
Craig -
Look here
http://screw.wz.cz/test/downloads.htm
....in the utils section. Look for avidefreezer2 and the accompanying guide -
You have two choices, using the latest version of Vdub (With a MMX problem that can stop the scan) or an old hacked Version called "vdub-mp3-freeze.exe"Originally Posted by Makaveli-swe
Vdub Normal
Video > Scan video stream for errors
If it finds any
Video > direct stream copy
Audio > direct stream copy
SAVE AVI
Note, that above is not suitable with problem VBR files, you would need to save out the whole AVI using full processing mode, uncompressed.
See also Vdub AC3
vdub-mp3-freeze.exe
Video > Check Video for Freezes
This makes a log of any bad frames at c:\badframes.log
You can then use that log to delete the bad frames (At the nearest keyframe) starting with the highest blocks of bad frames first.
12345
12346
12347
12348 (Delete these first)
1234567
1234568
1234569 (Delete these next)
http://www.digital-digest.com/dvd/downloads/virtualdub.html
Premiere CS3 exporting bad frames
By spicediver10191 in forum EditingReplies: 4Last Post: 17th Apr 2012, 18:39 -
Automatically Delete Select Frames
By mikesaunders in forum EditingReplies: 9Last Post: 6th Apr 2012, 01:16 -
batch detect and delete black frames
By boshreek in forum EditingReplies: 0Last Post: 25th Mar 2010, 16:47 -
fixing bad frames
By vidclip in forum Newbie / General discussionsReplies: 2Last Post: 10th Jan 2010, 16:00 -
Cutting bad frames with VirtualDubMod
By lazaruz in forum EditingReplies: 2Last Post: 18th Sep 2007, 04:39
