does anyone know how to fix or bypass this error while encoding from avi to mpeg1:Invalid Decimal Point Error, or something similiar to that matter, it happens in the middle while enconding
Results 1 to 9 of 9
somebody had this problem in a previous post, and they said they got rid of "junk" frames, I was wondering on how to do this, Does virtual dub do this?
you can use Vdub to do it by selecting check for bad frames, then saving the avi using direct stream copy.
Yep, that's a know errorOriginally Posted by DiabloTerrorGF
Use "vdub-mp3-freeze.exe" from
http://www.digital-digest.com/dvd/downloads/virtualdub.html or Kazza
Now select Video > Check video for freezes
This version makes a log of the bad frames at c:\badframes.log which you can use to "go to" the highest blocks first and delete them.
After you have deleted all
Video > direct stream copy
Audio > direct stream copy
SAVE AVI
12345
12346
12347 (Mark and delete these next)
234567
234568
234569 (mark and delete these first)
When you goto a frame, always click the yellow icon to jump to the nearest keyframe, before you mark the start or end
234569 Click one keyframe foward, mark end
234567 Click one keyframe back, mark start
Press delete key, do same for lower blocks (If any) -
oi... that is kinda confusing, but I got it, still, is there anyway to just copy the picture and sound to a new avi, or some way to fix bad frames, i missing half my movie that way, also how do i cut off black bars and stuff?
If you have that many bad frames, you better dump it..i missing half my movie that way
If the picture frame is for example 640 X 480 including the black bars, then think about it, you would need to "Stretch" the framealso how do i cut off black bars and stuff?
to a point where the black bars or no longer visible. If those black bars were equal (Left,right,top,bottom) then the stretch would be proportional, but the quality of a stretch image would look very bad. However if those black bars were only on the top and bottom, then the width is wider than the height, so now the picture will be elongated.
So you can't remove those black borders and expect the output to look good." full screen > keep aspect ratio" produces a good output, and on a widescreen TV you can zoom the borders out. -
my avi has a black bar to the right and some "mirror" type thing at the bottom
mirror ?
Well you can also use the crop function, while you experiment with the full screen or full screen > keep aspect ratio
pc crashes when using tmpge 4.0
By ANTS17 in forum Video ConversionReplies: 1Last Post: 11th Oct 2010, 23:55 -
.avs scripts in TMPGE Xpress?
By ecc in forum Video ConversionReplies: 0Last Post: 12th Aug 2008, 08:39 -
TMPGe and BD template the right settings for pal -getting juttering effect
By millzy in forum Authoring (Blu-ray)Replies: 0Last Post: 31st Jul 2008, 11:13 -
Get many error messages, AviSynth error message and meGUI error
By MKVcrazy in forum Video ConversionReplies: 0Last Post: 25th Aug 2007, 17:41
