how do i compress mpeg to any other format
without loosing some quality
you will always lose quality if you compress yet again a compressed lossy format ...
"any other format" is rather open ended -
You cannot compress, but you can re-encode to another format. DivX will produce a file one third to one half the size.
well - yes he can compress (more) to SOME other formats - though as you say, re-encode would be a better term to describe.Originally Posted by banjazzer
How about a Zip file then, or a RAR that should bring it down a bitany other format
Other than that, re-compress to DivX using Vdub
Mpeg 1, AVI > In , DivX AVI out
Install the Nimo Codec pack, then you will have a big list of codec's to choose from, also install Divx 5.02 (Kazaa) then you can also try that.
Video > Compression > Codec > settings
Audio > Compression> Codec > Settings
SAVE AVI
Quality, crap in crap out
How to compress this "mpeg nightmare scene" ?
By cd090580 in forum Video ConversionReplies: 35Last Post: 17th Apr 2009, 12:52 -
compress mpeg file
By bountylord in forum Newbie / General discussionsReplies: 4Last Post: 22nd Feb 2008, 11:33 -
Can i compress a
By YOURCONNEXX in forum Video ConversionReplies: 4Last Post: 9th Dec 2007, 13:03 -
how do you compress video
By wan2no in forum Newbie / General discussionsReplies: 3Last Post: 17th Aug 2007, 14:21 -
is it possible to compress HUFFYUV?
By Lee82 in forum Newbie / General discussionsReplies: 3Last Post: 10th Aug 2007, 13:56
