I was converting an avi file to mpg using TMPEG ... when I play the mpg file .. I get little cube once in awhile ... what can I do to fix that?
thanks
do I scan for junk frame of the avi file or mpg file? And where do I go in VirtualDub to do that? Sorry, not familiar with this program ..
really appreciate your help .. thanks. .. -
It is always best to edit AVI's and get them as best as possible before converting. Vdub does have a problem with scanning at times, which is a known problem, and we hope it will be fixed next time.
Vdub
Video > Scan video stream for errors
If it finds any, it will list them at the bottom of the screen, to remove them you only need to save out another copy of the AVI using streaming.
Video > Direct stream copy
Audio > Direct stream copy
SAVE AVI
If Vdub gives problems, you need to use an old hacked version called "vdub-mp3-freeze.exe"
Download from Kazaa or
http://www.digital-digest.com/dvd/downloads/virtualdub.html
This version make a log of the bad frames at c:\badframes.log which you can then use to delete the frames (At keyframes) starting with the highest block first
file converted from vob to mpg does not play on windows need assistance
By idealady in forum SVCD2DVD & VOB2MPGReplies: 17Last Post: 7th May 2010, 11:43 -
VOB2MPG (converted MPG file has no audio!)
By sonicdeth in forum SVCD2DVD & VOB2MPGReplies: 28Last Post: 5th Jan 2010, 19:23 -
decrypted, converted .vob to .mpg but have no menus
By chgoguy in forum Video ConversionReplies: 6Last Post: 8th Aug 2009, 16:03 -
How to save converted *s2d.mpg in another folder???
By junkfood in forum SVCD2DVD & VOB2MPGReplies: 1Last Post: 15th Sep 2007, 10:01 -
Spliting large mpg file into clips and saving each clip as a mpg file ?
By denise4gb in forum EditingReplies: 1Last Post: 6th May 2007, 17:52
