  1. Why is the movie freezing if I want to skip
    thanks
  2. Banned
    Jun 2001
    UK
    Skip ? Fast forward ?
    Probably not many key frames
    Atlantic Beach, Fl
    You might not have the flags set to seekable. Get ASFTools and fix it by setting the flags to seekable...
    Big_Jit
  4. but it will ask for a codec ( wmv1 ) I can't find it anywhere
  5. Banned
    Jun 2001
    UK
    Install the Nimo codec pack
    If the new Vdub gives problems, use Vdub 1.3C
