Hi, I did a search but I could not find an answer on how to burn a stanard vcd file that is more than 80 min long with nero.
I have a Plexor 12x10x32 and nero 5.5
I can overburn music cd´s. I once did one that was about 82 min or so.
But when I try do burn a Vcd file that is more than 80 min long nero wont even start to try to burn. Nero wil just say that there is no enough space on the cd. Even thought I have enabled overburning in the settings. I does not matter that the Vcd file is 80 and 10 sec long, nero wont even start burning. But if the file is under 80 min long nero will burn just fine. Or if it´s a music cd that is over 80 min, then overburning will work.
So my question is how to burn a vcd file that is longer than 80 min on a 80 min cd with nero?
//Kristoffer
You can overburn VCD's, god known i've done that lots of times myself, what I would suggest for you to do is, first create an Image File of the VCD you are trying to create, and then select Burn Image and Nero shouldn't give you any problem, it should give you a message saying that there isn't much space, and to either Cancel or Continue with Overburning.
Email me for faster replies!
Best Regards,
Sefy Levy,
Certified Computer Technician. -
Hi 9110,
Just to add. You need to ensure the DAO option enabled in Nero to overburn. I am sure you have checked this already.
How to rip a copy protected VCD and then burn to a CD
By c1steady in forum Authoring (VCD/SVCD)Replies: 4Last Post: 17th Jul 2009, 14:11 -
By c1steady in forum Newbie / General discussionsReplies: 3Last Post: 17th Jul 2009, 06:40 -
How can i burn a DVD or VCD with subtitles?
By Krimoon in forum Newbie / General discussionsReplies: 2Last Post: 25th May 2008, 15:41 -
how to convert and burn avi to vcd with cusoft
By brandon334 in forum Authoring (VCD/SVCD)Replies: 1Last Post: 21st Apr 2008, 18:49 -
How Can I burn a 90 min data CDR Image to HD Folder
By SCDVD in forum Newbie / General discussionsReplies: 1Last Post: 15th Feb 2008, 19:48
