HI
Has anyone had problems trying to open a mpeg 2 file captured with ATI
MMC 7.6 in TMPGEnc as I keep getting an error msg come up. I have tryed the mpeg 2 plugin for TMPGEnc but still can't get it to work. Any advice would be grateful.
Mike![]()
try selecting all files in open box...on my system tmpeg does not see mp2 unless you do this
Yep, MMC 7.7 does this (uses the mpg extension for mpeg-2), but with earlier versions you have to change it manually (or just upgrade to 7.7).Originally Posted by oldfart13As Churchill famously predicted when Chamberlain returned from Munich proclaiming peace in his time: "You were given the choice between war and dishonor. You chose dishonor, and you will have war."
The first time I installed TMPGEnc I didn't put the MPEG2 plugin into the TMPGEnc dir. I just ran the regupdate from where it was. When it didn't work I went back and read the directions and was able to do it the right way. After that I didn't have any more problems.
DXVA for VC-1 & MPEG2 on ATI card. How to?
By nic in forum Software PlayingReplies: 9Last Post: 3rd Jul 2010, 16:33 -
Anyone Have Experience Converting MPEG2 to H.264 with an ATI Avivo Card?
By drstew in forum Video ConversionReplies: 3Last Post: 24th Jun 2010, 10:00 -
MVK to MPEG2 - TMPGEnc
By zecaloteiro in forum Video ConversionReplies: 1Last Post: 18th May 2010, 08:32 -
MPEG2 files of VOB2MPG not accepted by ATI AVIVO video converter
By 33M344 in forum SVCD2DVD & VOB2MPGReplies: 1Last Post: 13th May 2010, 13:53 -
How to convert Mpeg2 to DivX using TMPGEnc and SimpleDivX
By rwmol in forum User guidesReplies: 14Last Post: 29th Jul 2007, 23:57
