Okay Guys and gals I have got a good one here.
After doing about 50 VCD decided to try SVCD
Encoded my film with TMPG in Standard SVCD mode ,created an
Meg2 File.Followed the instructions on site using Nero 5.5.9 to
author and burn ,Everthing went okay .but when I try to play the
disc "Power DVD" reports "A disk with Unsupported format in Drive H"
Then I tried with Ulead DVD Movie factory .Again when I tried to play the
Disk I get "A disk with Unsupported format in Drive H"
I can access the disk though my computer which shown the 4 correct files
and can ever open the Mpg file on disc and play through windows media
player ,Have tried to change the compatability format but with still
no joy .I am using Philips Rw Disk which work okay for VCD and assume
that because windows accesses them this is not the problems
Has anybody come up against this as I am at a total loss![]()
Paul
Keep follow up on this post..
http://forum.vcdhelp.com/viewtopic.php?t=102815
How to Author an SVCD with menus and stills Under GNU/Linux
By khey in forum User guidesReplies: 1Last Post: 24th May 2011, 23:35 -
Problem burning a project on to a DVD from TMPGEnc Author 3
By vhsal in forum Authoring (DVD)Replies: 5Last Post: 21st May 2011, 18:25 -
What do you encode and/or author your video to for burning?
By johns0 in forum PollsReplies: 10Last Post: 27th Nov 2010, 21:04 -
Svcd Burning
By Soixante in forum Authoring (VCD/SVCD)Replies: 4Last Post: 16th Apr 2008, 08:25 -
Burning folder with DVD Author 3
By Matt D in forum Authoring (DVD)Replies: 1Last Post: 11th Aug 2007, 15:06
