after being unhappy with my rempeg results and not being to get TMPG to work, i've decided to use CCE to transcode my video files.
i'm looking at doom9's guides and was wondering which one i should use:
getting the best of cce
or
IfoEdit and CCE guide
or do i need both?
i'm simply trying to transcode the video of Black Hawk Down (i ripped the extras out, i took out the unnecessary audio/subtitle tracks, etc.)
basically, can i just use the File Mode of dvddecrypter and then make a dvd2avi file and then use CCE? or do i have to do the whole complicated procedure in the second guide? thanks!
If you have a full version of CCE, I would suggest using DVD2SVCD - I get great results with it, with a minimum of effort.
gargoyle, do you have a link to a guide i could use with DVD2SVCD so that i know what i'm doing?
also, i tried the guide that PimpInDaHouse said to use and i was wondering if i have to do steps 3 and 4 (audio decoding and IVTC). i've never done anything with audio before, but is it necessary with CCE? and also, it says in the guide "IVTC (if necessary)". how do i know if mine is necessary? thanks again. -
You don't need to do step 3. Step 4 is if you are using NTSC but if you are using PAL or NTSC Film you don't need to do step 4. If you are using NTSC Film you will have to do a 3:2 Pulldown which you do with the program you can download there you just drag and drop in the program window and it starts for you.
Guide wrong? "Converting a PAL DVD to NTSC using CCE"
By OliverGrey in forum Video ConversionReplies: 2Last Post: 11th Jan 2009, 01:47 -
TV Guide/Guide Plus+ After Feb. 2009
By handyguy in forum DVB / IPTVReplies: 0Last Post: 30th Oct 2008, 10:34 -
CCE guide for PAL to NTSC conversion
By alexs_eu in forum Video ConversionReplies: 9Last Post: 21st Jun 2008, 07:41 -
guide for ssa
By pcb in forum Newbie / General discussionsReplies: 1Last Post: 29th Apr 2008, 20:42 -
HC Guide?
By Rauli in forum Authoring (DVD)Replies: 6Last Post: 10th Aug 2007, 22:34
