Hi I made a svcd using tmgenc i used 3 cds i think the bitrate was like 2250 ok my question is the picture is beautiful aside from one thing. Maybe once in the whole movie there is like tiny little colored boxes that flash across the screen. But it doesn't do it all the time sometimes the movie will play perfect other times it won't usually it pixelates in the same spot though.
Can any one help me? PLease
Try StreamFab Downloader and download from Netflix, Amazon, Youtube! Or Try DVDFab and copy Blu-rays!
does it do it when you play the FILE on your pc ? if not, its prob the cd media you are using -- like get better disks , clean it , clean your player , etc ...
It sounds like a few frames in your file are corrupt. It happens often when you download a file. If it really bothers you, you can simply delete these frames with vdub.
I've found some AVIs that required the SMR patch from the codec section on this site. If I tried to use TMPGEnc to convert to MPEG1 without it I would get these usually purple blocks that would come and go. This may not be helpful since you you're dealing with MPEG2 but I thought I would throw it out there.
Take it easy. And if its easy take it twice. -
Yes but this was a dvd rip to svcd so I have the movie. I ripped it straight from the movie
What is so funny is that first cd i burnt straight from the image file and i watched the whole movie and it was beautiful then i tried to make a copy of the burnt movie and it has pixelization in certain parts of it. What causes this.?
Also the movie said it was letterboxed so I selected 16:9 and it created it with two extra black bars at the bottom so the movie has the original black bars at bottom then one more on top of them
Newbie that needs answer to a question: Transferring videos to a Mac?
By PlatS in forum Newbie / General discussionsReplies: 11Last Post: 10th Nov 2010, 23:28 -
can someone answer a general aspect ration question to me
By consumerx in forum Newbie / General discussionsReplies: 4Last Post: 1st Nov 2010, 10:58 -
FAQ didn't answer my question. What's the best DVD-R 9GB media to buy?
By insomnia976 in forum MediaReplies: 7Last Post: 18th Jul 2009, 13:10 -
Question closed. Reason: answer found elsewhere
By Hurdman in forum SubtitleReplies: 0Last Post: 9th Dec 2008, 02:54 -
Hard question that nobody can answer: Why LCD > CRT?
By SignedupGuest in forum Newbie / General discussionsReplies: 31Last Post: 20th Jul 2007, 11:34
